Hd Tranny?
well tomorrow will be 1 week with my new/used truck. it has 60k on it and i have some questions.
i never rode in a 5 or 6 sp truck so it has me worried a little.
the shifting in auto is hit and miss. 1st to 2nd seams firm sometimes and 2nd and up soft. but other times 2nd to 3rd is firm. is this normal? this is noticed when being easy/ rolling into the gas. hammer down its fine
when im crusing behind a slow person around 35 to 40 mph and doing small rolling hills. when ya let off and coast then get into the gas again, it seams like it doesnt know which gear it should be in and stumbles to find that perfect gear. is that normal?
when ya come to a stop, and ya roll it a little and go, the same thing happens, it doesnt know what gear to be in to take off again.
1 more, lol. from the forum i was told i got a 6L90-E transmission. if this is a 6 speed tranny, why is it if i use manual shift mode i only have 5 forward gears?
any thoughts or input would be awsome
thank
Check with the dealership and see if the programming has been applied to the TCM for the upshift/downship issues your having. Thats been a BIG complaint with early 6-speeds. As far as the 6-speed, are you counting overdrive too?
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,123 Guests (See full list)
