sound system
Guest SiiLT_old
Guest SiiLT_old
How much money are you looking to spend?  What type of music do you listen to(i am assuming rap, thats usually what two 12's means)?  What do you want to do, add an amp and subs or replace your deck , etc.?
Guest SiiLT_old
Ok.  I almost bought a similiar setup.  I would get two 12" Kicker squares.  nothing, and i meen nothing(for the $$) will compare to these things.  Power it with either a MTX 8100D or if your on a budget slightly under power it with a lanzar 1200d.  I was going to get the lanzar, because it is the best bang for your buck amp out there.  I was going to get two 10 tho but my bud at school has underpowered 12l7's and trust me, even at 600w each these puppies hurt!
lanzar bad, it'll die. spend some more money and get a stronger amp.
seen lots of last year model amps on sale. just look around you can get something that has better quality and will last.
no point in buying good subs and killing them with a high distortion amp.
    contrabombarde
    contrabombarde
  • Who's Online   0 Members, 0 Anonymous, 857 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
