Getting started on my system.
Yesterday went out and bought an amp, its a  Rockford Fosgate Punch 200 for $180  :D. When I get my money back for my car that I just sold Im going to go and get the JL 10W0 and box.  I cant wait to get some more bass back.  :D
Just a suggestion, you might want to get a 10w3d2.
I was going to get a 10w0, but for 50 bucks more, you get so much more speaker for your cash(they wanted 100 from one place I went to for the 10w0).  Just put the 2 side by side without even listening to them and you'll see what I mean.  Plus the w3d2 is a dual voice coil.
Also, the 10w3 is rated to 250 continuous watts where the 10w0 is only rated to 125.
Just a suggestion. :D
I have my sub run off of 2 channels from my 50x4 kenwood amp(the front channels go to the front door speakers) and it provides more than enough bass.  The kind of bass that really hits the back of your head when cranked, know what I mean?
;)   And I'm not even getting maximum use from the woofer.  I guesstimate that I'm getting about 125 or so watts to it.
just so you know  that punch 200 is gonna put out a HUGE amount of power just for one sub,  I have one that I ran 2 15" kicker comps off of and it would pound them to death.
If you are intent on just running one   make sure you turn that amp all the way down and don't bridge it.
well i planned on getting two but my buddy is probably going to move to Tenn.  And I dont want to have my whole floor under my back seat taken up by a box.  The box I was planning on making would hold to and have the area were the trans. hump as a tool box area. So ill go with just one  for now and see if I like it or not.  If I dont Bridge it than I will only be putting 50 watts to the sub, and it can handle 125.  Ill have to try both ways. Thanks.
you'll get alot more power out of the amp than whats it's rated for   my kicker zr360 we just put in is rated at like 130 but it's pushing out 740 watts.
    Sothpaw27
    Sothpaw27
  • Who's Online   5 Members, 0 Anonymous, 635 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
