1500hd upgrade
planning on changing all 4 door speakers out, installing alpine's and drive them with a 100w amp. i going to install a 10" sub, powered by a 100w amp. i don't plan on changing head unit. how will this setup sound? having trouble building sub box that will work under backseat...any info will be appreciated
which alpine speakers? what kind of amps? 100watts peak? rms?  thought about using a multichannel amp, like 5 channels or so? what kind of 10" sub? what are your goals for the system, sound quality or SPL? kind of need a little more detail on the stuff. if everything is done right it'll be better then stock. i cant say leaving the stock head unit is a good idea if your changing everything else. thats almost always the first thing i change. but if cost is the biggest problem for that, just wait till you can afford it and it'll sound even better. and you will love your truck just that much more.
Copper, I am in the middle of a similar upgrade with my HD.
I have replaced all 4 door speakers (Alpine front, Fosgate rear).
I have a Fosgate punch amp to run the sub.
The sub box dimensions are
Measurements are:
H = 7.5" (front) & 6.5" (rear)
W = 13.5
D = 15"
It holds a 10" and has .5cu ft
Here is a pic
http://photos.yahoo.com/bc.....view=t
I am changing the HU but the 2002 Alpines are not in yet so I am patiently waiting.
You HAVE to change out the HU!!!!  It will sound worse with aftermarket speakers!  I was told this by my local shop and they were right!  Your wasting your money if you don't
Offroadr -  Where are you mounting the amp?  I'm contemplating adding a sub to my ext. cab.  I already have a fairly large Alpine amp, but haven't decided on location that's out of the way.  I fold the rear seat up a lot during the winter so that I can hold my ice fishing equip without getting the seats wet and full of snow, so I'd like to be able to put it someplace that's out of the way and will have good circulation.
Firetiger, I am mounted mine behind the sub box it is completely out of the way.  But understand that I have have a crew cab and the way the seats fold are completely different than an ext cab.  (Actually I think the ext cab seats have a better design that give you more room.
on the rear wall behind the rear bench works fine, i can still fold up the bench seat in my K2500. it rubs, but still can be done.  as long as you arent pushing the amp like there is no tomorrow your amp should be fine. if you get worried. add some fans. (good amps shouldnt even break a sweat when not trying to reach crazy spl)
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 407 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
