Driver's Side Seat Warmer Shuts Off
2003 Yukon Xl, recently had a malfunctioning seat warmer on the drivers side. It will initially turn on for about 5 seconds, then shuts off automatically. If pushed again, it turns on then off right away. It now has a click that comes from the button on the door as well as under the seat. The passanger side seat still works. Is it the heating element? Doesn't seem to be wiring if it will send a current. Maybe i'm wrong. Any help? Not excited about going in to the dealer to get a multiple answers for a big $$$$.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
