Door Actuator And Service Bulletin
coosacat
Had drivers door actuator replaced and now my interior lights dont work when you open the drivers door. Think I saw a bulletin about the actuator wiring now working correctly and causing the radio to not cut off when the door was opened. Mine cuts off and everything else seems to be ok except for the interior lights. Do I have a faulty part.
Thanks
The dome switch is on. The lights all work with the other three doors just not the drivers door. The locks all work fine now. I was wondering if maybe there was something in the wiring.
It could be the wiring issue then. The bulliten is PIT4758B Document ID:2239554. Could be a faulty part could be the wires need changed. Take it back in and let them make the determination.
