Strange Unknown Button On Climate Control
I have this unknown button on my climate control interface, the manual says it's the rear defogger, but it looks like it's a side view mirror defroster. It's the second button from the LEFT, bottom row. Any ideas?
If you have a rear window defogger, and heated mirrors, it operates both together at the same time. I assume if you only have the heated mirrors, then the symbol on the button might look like the mirror instead?
Exactly,If you have just the heated mirrors,and no rear window defogger,the symbol looks like a mirror.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,183 Guests (See full list)
