Window Regulators
digicom1
four manual window regulators with the handles they were on the truck about 1 week lessthan 100 miles before i changed them out for electric ones gmt 900 cc make me an offer i just want to get rid of them
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
