2008 Sierra Tranny Cooler
i just picked up a aftermarket tranny cooler and i am going to install it soon and was wondering how it hooks up to the tranny lines that goto the factory cooler am i able to just slip the new line over that old line does it have a flare on the end i would like to have some what of an idea how this works and if i need anything before i take it apart.
i have installed tranny coolers before the only thing that i am unsure of is how the alum line hooks up to the factory cooler in front of the rad. and when i take out the fact cooler and put in my tru-cool is there some kind of flare or a bump in the line that i can slide my hose over and clamp it or will i have to cut the line and flare it my self or do i have to get a comprestion fitting and clamp the ring around the line to give me somthing to stop the clamp from sliding off
Mullet,
The cooling line attachment that GM used is called the "quick disconnect" for the a/t cooling lines. There is a bump/rib at the end of the tube that should suffice as a keeper for your hose and clamp. I don't think it's a traditional flare like on a brake line, but more similar to a fuel line connection. Good luck.
If you have the tow package Z82 you should have KNP aux trans cooler. Look in the glove box for those RPO's.
oh ya its a 1500 with the tow package and a 4x4
    bellssn690
    bellssn690
  • Who's Online   2 Members, 0 Anonymous, 522 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
