Gm 8.6 Differential Bolt Specs
Hello All,
Soon I will replace the rear carrier on my 2008 Silverado 1/2T 4WD. I am looking for the ring gear and carrier bearing torque specs.
Regards,
Keith
Hello All,
Regards,
Keith
Bump :thumbs:
Service Information
2008 Chevrolet Silverado - 4WD | Sierra, Silverado (VIN C/K) Service Manual | Driveline/Axle | Rear Drive Axle | Specifications | Document ID: 1613123
Fastener Tightening Specifications
Application
Specification
Metric
English
Axle Flange Bolt (10.5 Inch Axle)
156 N·m
115 lb ft
Axle Flange Bolt (11.5 Inch Axle)
185 N·m
136 lb ft
Bearing Cap Bolt (8.6 Inch Axle)
75 N·m
55 lb ft
Bearing Cap Bolt (9.5/9.5 Inch LD Axles)
85 N·m
63 lb ft
Bearing Cap Bolt (10.5 Inch Axle)
185 N·m
136 lb ft
Bearing Cap Bolt (11.5 Inch Axle)
207 N·m
153 lb ft
Brake Backing Plate Bolt
135 N·m
100 lb ft
Brake Hose Bracket Bolt
22 N·m
16 lb ft
Brake Pipe Bracket to Rear Axle Bolt
22 N·m
16 lb ft
Brake Pipe Bracket to Rear Axle Nut
13 N·m
115 lb in
Brake Pipe Junction Block Bolt
22 N·m
16 lb ft
Differential Bearing Adjuster Nut Lock Bolt (9.5/9.5 Inch LD Axles)
26 N·m
19 lb ft
Differential Bearing Adjuster Nut Lock Bolt (10.5 Inch Axle)
27 N·m
20 lb ft
Differential Bearing Adjuster Nut Lock Bolt (11.5 Inch Axle)
27 N·m
20 lb ft
Fill Plug
33 N·m
24 lb ft
Flex Hose Bracket Bolt
12 N·m
106 lb in
Pinion Gear Bearing Retainer Bolt (10.5 Inch Axle)
88 N·m
65 lb ft
Pinion Shaft Lock Bolt (8.6 Inch Axle)
36 N·m
27 lb ft
Pinion Shaft Lock Bolt (9.5/9.5 Inch LD Axles)
50 N·m
37 lb ft
Propeller Shaft Yoke Retainer Bolt
25 N·m
18 lb ft
Rear Axle Housing Cover Bolt
40 N·m
30 lb ft
Ring Gear Bolt (8.6 Inch Axle)
120 N·m
89 lb ft
Ring Gear Bolt (9.5/9.5 Inch LD Axle)
140 N·m
103 lb ft
Ring Gear Bolt (10.5 Inch Axle)
165 N·m
122 lb ft
Ring Gear Bolt ( 11.5 Inch Axle)
237 N·m
175 lb ft
Shock Absorber Nut - Lower
95 N·m
70 lb ft
Stabilizer Shaft Link Bolt
95 N·m
70 lb ft
Stabilizer Shaft U-bolt Nut
32 N·m
24 lb ft
U-bolt Nut
72 N·m
53 lb ft
U-bolt Nut (25/35 Series)
150 N·m
110 lb ft
Wheel Hub Nut (10.5/11.5 Inch Axles)
70 N·m
52 lb ft
Service Information
Application
Specification
Metric
English
156 N·m
115 lb ft
185 N·m
136 lb ft
75 N·m
55 lb ft
85 N·m
63 lb ft
185 N·m
136 lb ft
207 N·m
153 lb ft
135 N·m
100 lb ft
22 N·m
16 lb ft
22 N·m
16 lb ft
13 N·m
115 lb in
22 N·m
16 lb ft
26 N·m
19 lb ft
27 N·m
20 lb ft
27 N·m
20 lb ft
Fill Plug
33 N·m
24 lb ft
12 N·m
106 lb in
88 N·m
65 lb ft
36 N·m
27 lb ft
50 N·m
37 lb ft
25 N·m
18 lb ft
40 N·m
30 lb ft
120 N·m
89 lb ft
140 N·m
103 lb ft
165 N·m
122 lb ft
237 N·m
175 lb ft
95 N·m
70 lb ft
95 N·m
70 lb ft
32 N·m
24 lb ft
U-bolt Nut
72 N·m
53 lb ft
150 N·m
110 lb ft
70 N·m
52 lb ft
Thanks for the Information!
Those ring gear bolts get quite a bit of torque! Do folks typically reuse them or install new? My truck has 20K on it.
Regards,
Keith
They want you to use new bolts....
Service Information
2008 Chevrolet Silverado - 4WD | Sierra, Silverado (VIN C/K) Service Manual | Driveline/Axle | Rear Drive Axle | Repair Instructions | Document ID: 2213437
Drive Pinion and Ring Gear Replacement (8.6, 9.5/9.5LD, and 11.5 Inch Axles)
Special Tools
• J 22536 Pinion Driver, 8.6 inch, 9.5/9.5LD inch axles
• J 44421 Pinion Remover, 11.5 inch axle
Removal Procedure
Raise the vehicle. Refer to Lifting and Jacking the Vehicle.
Remove the differential assembly. Refer to Differential Replacement.
Remove the pinion yoke and the oil seal. Refer to Drive Pinion Flange/Yoke and/or Oil Seal Replacement.
Important:
• Ensure that the J 22536 or the J 44421 is firmly seated on the pinion.
• Do not let the pinion fall out of the rear axle housing.
Using the J 22536 driver, 8.6 inch, 9.5/9.5LD inch axles or the J 44421 remover, 11.5 inch axle and a hammer, the drive pinion gear.
Remove and discard the collapsible spacer from the pinion.
Remove the pinion bearings and the cups. Refer to Drive Pinion Bearings Replacement.
Important: The ring gear bolts on the 8.6 inch and the 9.5/9.5LD inch axles have left-hand threads. The ring gear bolts on the 11.5 inch axle have right-hand threads.
Remove and discard the gear bolts.
Notice: Refer to Ring Gear Removal Notice in the Preface section.
Remove the ring gear from the differential. Drive the gear off with a brass drift if necessary.
Installation Procedure
Important: The mating surface of the ring gear and the differential case must be clean and free of burrs before installing the ring gear.
Install the ring gear to the differential case.
*Important: The 9.5/9.5LD inch axles have left-hand threads. The ring gear bolts on the 11.5 inch axle have right-hand threads.*
Hand start the NEW ring gear bolts.
Notice: Refer to Fastener Notice in the Preface section.
Important: Tighten the ring gear bolts alternately and in stages, gradually pulling the ring gear onto the differential case.
Tighten the NEW ring gear bolts.
Tighten
• For the 8.6 inch axle, tighten the ring gear bolts in sequence to 120 N·m (89 lb ft).
• For the 9.5/9.5LD inch axles, tighten the ring gear bolts in sequence to 140 N·m (103 lb ft).
• For the 11.5 inch axle, tighten the ring gear bolts in sequence to 237 N·m (175 lb ft).
Install the pinion bearing cups. Refer to Drive Pinion Bearings Replacement.
Determine the selective shim thickness for the pinion gear. Refer to Pinion Depth Adjustment.
Install the selective shim onto the pinion.
Install the inner pinion bearing to the pinion. Refer to Drive Pinion Bearings Replacement.
Install a NEW collapsible spacer.
Lubricate the pinion bearings with axle lubricant. Refer to Fluid and Lubricant Recommendations.
Install the outer pinion bearing into the axle housing.
Install the NEW pinion oil seal. Refer to Drive Pinion Flange/Yoke and/or Oil Seal Replacement.
Install the pinion into the axle housing.
Install the pinion yoke. Refer to Drive Pinion Flange/Yoke and/or Oil Seal Replacement.
Install the differential assembly. Refer to Differential Replacement.
Fill the axle with lubricant. Use the proper fluid. Refer to Rear Axle Lubricant Replacement.
Lower the vehicle.
