Nbs Dl3 Mirror Upgrade Curb Assist
I am going to do a DL3 mirror upgrade on my 08 Silverado LT1 CC. I read plenty of post on this forum, I think I have it figured out except for the curb assist.
I am of the conclusion that to power seat memory module under the driver's seat controls the curb assist feature. It makes sense because the seat memory module also uses the position sensors in the DL3 mirrors for driver position memory.
Since I do not have a memory seat module, and still want the curb assist feature, can I add a memory module for the curb assist feature only. It would be an easy hookup once the DL3 mirrors and DDM, PDM are installed. Looks like it would only be three wires on the memory module that are needed, sw batt, ground, gmlan. If a I get a used one, the dealer would not even need to program it...
Has anybody tried this? Are there any GM techs with thoughts on if this will work?
Thanks
Thanks
Which door panels do you have? The true truck version's door wiring may not be compatible with the connectors on the door modules. If you have the lux, then you should be ok. You say you have an LT1, so I am assuming true truck, there are two types of switch panels in these, one works and one does not. Good luck and let us know.
Thanks
Guess what, I have the door panels with the wrong connectors. Oh well, I only purchased the switches so far. So, I guess they go in the ebay pile!
Thanks,
WAIT WHAT SWITCHES DID YOU BUY? I BOUGHT A SET OF DL3 MIRRORS FOR MY 08 YUKON AND BOUGHT THE SWTCHES BRAND NEW. THE DRIVER AND PASS SIDE. COST ME AROUND 200 BUCKS! DID YOU BUY THE SWITCHES FOR THE LTZ SILVERADO? I BELIEVE THEYRE THE SAME. IF THEY HAVE THE BIG ROUND MIRROR ADJUST SWITCH THEN THOSE ARE THE ONES I NEED. HOW MUCH DID YOU PAY FOR THEM?
I purchased the LT2 switches, silver finish on the bezel, not wood. They were removed from a crew cab that had 8 miles on them, I think I paid $120 for the pair. Also, since they were already installed in a truck I was hoping they were already programmed and I could avoid the dealer.
damn thats too bad theyre the wrong switches for me or id take them off your hands. like i said im doing the upgrade on my 08 yukon and i only need to replace the driver side switch and program it and voila i have dl3 mirrors.
    Bulldogger
    Bulldogger
  • Who's Online   3 Members, 1 Anonymous, 728 Guests (See full list)
    • I figured you would know about it.
    • It added a cost layer to an already limited production supply. True that.
    • Swap costs and supply/demand balance. When a barrel comes out of the ground the entire range of products are present but not all at the same percentage.    Breakdown of Refined Products The following table summarizes the approximate output from a standard 42-gallon barrel of crude oil: Product Type Gallons per Barrel Percentage of Total Gasoline 20 gallons 45% Diesel Fuel 9 gallons 21% Other Products 13 gallons 31%   Most of that diesel figure is 'straight run' or cut from the barrel. Gasoline 'cut from the barrel runs 0 to 20% at the crude. So in the crude unit there is more diesel the gasoline, usually.  The full refining experience however gives the tabled values. Ego there is half the diesel than gasoline after the 'first crack' That could be an FCC unit, or Isomax or....   Those units take heavy products and break the big ones into little ones. Those numbers are harder to get hold of but directionally it ends up the same.    Really light products are very profitable. Ethylene and Propylene to name two. Those are cracked from slightly heavier feeds like NG and Propane and Ethane. The cracker harshness determines the feed for distillation. Those feeds come from less profitable products like diesel and gasoline.    So...there is a swap cost. How much market is there TODAY and what crude am I running TODAY..... what is my process capable of always.    There is this as well. The USA uses allot more gasoline than it does diesel so in the cracker the process is tilted to gasoline production which....limits supply of diesel. OTR uses the most and it has different requirements than automotive and agricultural.  Limiting auto products.    You are correct however. It is less refined, just less of it. Allot less.
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
