305-40-22 On 07 Sierra Denali
Will these fit without any rubbing on stock suspension? Or do I need a leveling kit? If anyone is running these please post a pic.
You should be just fine as long as the offset of the wheel is proper. I ran the same size tire with a 2 inch drop on my 08 and only slightly rubbed the front mudflap on hard turns. hope this helps.
I was running 305/50/20's on my 07 Denali with a little rubbing when the truck was turned to maximum radius and tweaked a bit. Was glad to get rid of them when I went back to 275/55's.
I ran them on my truck with a +25mm offset wheel. Stock= no rubbing, 2/4 drop = no rubbing, 4/6 drop = rubbing at max turn.
    ar0517
    ar0517
  • Who's Online   5 Members, 0 Anonymous, 636 Guests (See full list)
