Need A New System In 01
I have a 01 silverado crew cab. one of my rear speakers blew and the left from crackles. So i figured now was a good time to get new speakers. So i went out and bought a couple to try but it seems like none of them have the same bass my stock speakers had. Im trying to keep my stock head unit but if i have to ill buy a new one. SO what i am looking for is a good set up i should buy. like to try to keep it pretty inexpensive. The front has tweeters too correct? I will probably just start with speakers first, but i want something with some bass. I also tend to hate the look of the aftermarket head units for some reason
    Sothpaw27
    Sothpaw27
  • Who's Online   5 Members, 0 Anonymous, 696 Guests (See full list)
