Muffler For 05 2500hd 6.0
hey guys, im new to this site and im having a hard time navigating the site, so not sure if this was posted before
but, im looking for a muffler for my 05 2500 6.0, not the full exhaust system, due to cost..
i would prefer a magnaflow or flowmaster since they are easy to aquire around here, help me out! thanks :cool:
I forgot the part number, but the big block dual inlet, single outlet muffler from Flowmaster is the one I got. I love it. I have had it on the truck since i basically bought the truck.
I used flowmasters for years and put one on my truck...after 2 years, a baffel weld broke and it made an awful racket. I switched to a magnaflow and am much happier....more mellow one, not raspy. Performance was the same....none....ha. My son heard the magnaflow and immediately took his truck in for one...his 8.1 sounds fantastic.
Try the biggest flowmaster they offer, I think it's the 50series HD. I don't think you'll be dissapointed. Flowmaster gets a bad rap b/c everyone seems to think the need the 40series which are tiny street rod mufflers.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 831 Guests (See full list)
