Different Interior Options
Hey all, i recently pruchased a 93 gmc sierra sl 4x4 k1500 (single cab) and my buddy has one maybe a year older but mine has a rear slider window and his does not, also he has trim going from bottom to top in his rear cab corners inside, and has regular carlike roof liner, my truck has a vinyl push pin roof liner and only trim at the bottom of cab corners inside mine doesnt go all the way up, and my speaker covers snap right into the steel cab mine are not build into the trim like his, but other than that interior is identical i was wondering depending on the trucks package or style do some come with different interior options or am i missing trim? thanks for the help
It's just a difference in trim level, his is probably an SLE. I worked with a guy who had a 93 Chevy C1500 and his had the "Cheyenne" package; even though his had the composite front end (not the W/T single sealed beams) it had the same interior that yours has. It seems to be a kinda "middle of the road" interior.
cool thanks for the info bro, wasnt sure if i was just missing trim or not, looks like i have the W/T package.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
