For Sale 1992 Gmc Typhoon
Ok do to a lot of life changing things that have just happened Like twins instead of just 1 new baby and being in a financial mess business wise (Need some new equipment)
We have decided to sell the Typhoon. Since we have owned it all I have done is fix all the small issues it had.
1- Brand New 60lbs Injectors
2- New Fuel Pump and Sending Unit (Gas gauge now works)
3- A lot of wiring issues and 2 ground problems
4- New 16 possition Chip by Nolan at Cambal automotive
5- Rear Brakes
6- Oil leaks
Info on the truck -
1992 Typhoon #1606
Stock block
Nitride d stock crank
L35 heads
Eagle forged rods
TRW forged pistons
Harland Sharp 1.5/1 roller rockers
Crane Hydraulic Roller Cam
Melling Oil pump
PTE51 turbo w/3" downpipe and cutout - internal wastegate w/new actuator rod
RPM 3" stainless exhaust (I have it dumping out right in front of rear axle)
RPM Dual Electric Fans with Aluminum upper/lower shroud
Edelbrock water pump
A2A front mount intercooler - polished piping/Treadstone performance silicone connectors
Knockoff HKS SSQV blow off valve
Manual boost controller set to 15psi (rock solid)
60# injectors
180 deg thermostat
Jeep steering shaft from board member fivetodrive
Kenne Bell AFPR
Exterior
Repainted in March '09 with Sikkens Arctic White (Corvette white)
Body is in mint shape
Clear corner lenses
HID headlights
Black GMC grill letters
Shaved "escutcheons"
New Gray Typhoon logos (GMC Truck Motorsports on tailgate)
Brand new PPG windshield and molding
New wipers and wiper arms
Rear wiper delete
Roof rack shaved
Morxchn style Gunmetal Z06 wheels w/polished lip (17x9.5 all four corners)
Federal SS595 275/40/17 tires (maybe 300 miles)
All new plastic rivets attaching the cladding
Interior
9 out of 10
Seats are in excellent shape - very little sign of wear
NO cracks in dash whatsoever
Carpeting is perfect
3 gauge pillar pod (Ultimate display, autometer boost/vac, tranny temp) - tranny temp not hooked up
New headliner
Manual fan override switch
Miscellaneous
Camball automotive 16 postion chip 6 street settings and 6 110 octane settings and 4 116 octane settings (Currant setting is # 6 for 110 octane
A/C delete
ABS delete
Cruise control delete
Tranny cooler mounted to core support w/aluminum brackets
Jeg's small radiator catch can mounted where vapor canister used to be
New stock style radiator
built 700R4 tranny - have receipts
Bilstein shocks - installed by previous owner
Belltech 3" drop leaf springs w/1" blocks and pinion correcting wedges (bought from Jags That Run)
Front lowered by turning torsion bars
New power steering pump/pulley
Optima Red top battery
K&N 3" air filter
3" Cobra elbow off the turbo
Completely rebuilt turbo in April 09 (bearings/seals)
Polished Typhoon plate on upper intake
New stock style distributor, ignition module, coil
Just did tune up - new cap, rotor, plugs (NGK UR6 gapped to .2, wires (Taylor 8mm Spiro Pro),
fuel filter
ALDL cable for datalogging
New GM knock sensor
ECM relocated to glove box for easy access
K&N Breather filters on both valve covers - NO PCV
New GM torsion bar mounts
Tons of new hardware throughout the truck
RPM Braided turbo oil drain line with -AN fittings
RPM Brake Booster hose
Asking price is $11,000 or maybe part trade on a Nice lifted 4 Seat Golf cart or another nice Car plus cash on your end :thumbs:
Please Call 313-724-8434 for a time to come and look at it if your interested in Purchasing and if you have a trade please email me with a photo of the Car or truck and detailed info including what it runs and whats been done to it. If there is no info with the trade request I will not respond. THANKS!
Very nice Typhoon..good luck on the sale! :happysad:
I remember drooling over these many years ago when I was running around in a 1992 GMC Jimmy SLS. I hope GM makes another performance SUV, no more Typhoon, no more TBSS :lurk:
    CaptainDad
    CaptainDad
  • Who's Online   1 Member, 0 Anonymous, 531 Guests (See full list)
