Front End
Ok here it is i have a 1995 gmc k1500 suburban....lately ive felt a rubbing in the front end when i hit bends to the right in the road,,,,,not when i turn right but as im driving and hit a right bend the passenger side feels like its grinding i can feel it in the brake pedal...so here what i did so far i changed the rotors ,calibers new brakes and still have the issue when i shake the wheel up and down it doesnt move...but side to side i do have some play ....i was looking at doing all the ball joints but afarid to spend the money if it's not it? Also i was looking at a sterring stablizer but not sure if i need one....did anyone else ever have this kind of issue ? like i said it only happens on turns to the right....also the abs wire on that side broke could that make it grind?..thanks for anyhelp brandon..
Have you checked wheel bearings?
never pulled the tires off when i shake them up and down there tight they dont move at all ...and if it was wheel bearings wouldnt it grind all the time?
Not when they first start to go bad, I would guess that it is the bearings.
    Camyon
    Camyon
  • Who's Online   4 Members, 1 Anonymous, 1,256 Guests (See full list)
