HPP3 Question
Question for all you HPP3 folks - when you remove the speed limiter does the speedometer register above 100 when you go above 100 if you have the Denali or Escalade cluster?
The reason I am asking is that the Jet Performance SCU 2000 doesn't - it appears to just fake it in the high 90 range and let you keep going - you have to ask the radar mountie what the speed was. Not complaining as I just wanted it out of the way for testing and the track - get my mph on the slip and from my Tazzo. :thumbs:
gandolphxx, do you have the Jet Performance SCU 2000?  If so, how do you like it?  I am interested in getting something to correct my speedometer for larger tires but don't want to spend the $300+ on the Hypertech.  I don't need the performance boosts either...just the fix for larger tires.
Any information on the Jet SCU would be greatly appreciated.  Thanks.  B.J.
Has anybody tried to use 1 HPP3 on 2 or more vehicles?  Either of the same year or not?  I have a friend that also has an 02 AV and we'd like to split the cost of the HPP3.  But I'd like to find out first if 1 HPP3 can be used on more than 1 vehicle.
Thanks
MI 99XPL
I asm going to install tomorrow, will post results, have heard that they don't do well in heat, bummer, I live in houston=heat. :thumbs:
Thanks
MI 99XPL
It is my understanding that you have to revert to stock to uncouple it - therefore, no sharing :thumbs:
Exactly!  Hypertech didn't want one person buying their programmers, then distributing it to their friends after they were done.  Essentially when the HPP downloads it's new programming to your PCM, it stores your factory settings, so that when you remove the HPP, it'll return your PCM to it's pre-HPP settings.
I'd be interested in hearing your results with the Jet.  See my thread about HPP not allowing for tire size changes.  Allison won't release them or something.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,218 Guests (See full list)
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
