Cargo Management System Removal
I would like to remove the Cargo Management SYstem (CMS) to do some work but have a question. There are 3 bolts holding them on for each side rail. If I remove the bolts from the bed side, are the nuts welded onto the inside so they will not fall or will I need to have "go-go gadget arms" to get to them?
Thanks
The nuts are like small anchors like you would use to hang something on a plaster wall. You stick them through the hole and they expand out. You should be able to loosen the nuts and the work them out of the hole without them falling off of the bolt.
These are tricky to remove, but not too bad if you take your time. Some of them will simply fall to the ground, but the ones that won't, use a long skinny screwdriver to work the nut/anchor out the hole.
  • 1 year later...
Old thread, but all mine came out fine without dropping any into the truck body or on the ground.
I removed the bolts all the way and the anchor nuts stayed attached to the black plastic parts.
Then I held the rail frimly against the bed and stuck a long skinny screwdriver through the bolt hole and pressed on the bottom half of the anchors to rotate them 90* so they would pull straight out of the mounting holes while still attached to the rail and plastic part.
[img]http://i17.photobucket.com/albums/b66/Hogbear/001-6.jpg[/img]
[img]http://i17.photobucket.com/albums/b66/Hogbear/002-7.jpg[/img]
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 636 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
