Gm Mp3 Player Problems
I just purchased a 2008 Silverado 1500 LT1 last week. I'm loving the truck and looking forward to getting more involved here and adding some mods to the truck.
Anyways, I'm having a problem with the stereo. This is a CD player w/o bose or dvd. The two things that are happening are as follows:
1. The mp3 ID tags do not show the song info. It will show "yb and the 1st letter of the song" Like for the song "Like a Rolling Stone" it will show "ybL"
2. Also, with a MP3 CD if I turn the truck off in the middle of a song, when I start the truck again it starts at the beginning of the song instead of where it left off.
Has anyone had/fixed this problem?
  • 8 months later...
I have been having the same issue. I have tried to create cd's in two different ways. One way using a software disk burning program, the other was to dump a bunch of MP3's onto a dish through Windows with no luck. All of my MP3's are top quality rips, and properly tagged and I get the same issues you mentioned
    Fishboat
    Fishboat
  • Who's Online   1 Member, 0 Anonymous, 525 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
