99 2wd Rear Diff Fluid?
I have a 1999 2wd 4.8l and I need to change the Rear diff fluid but I have no idea what fluid it takes or if it needs additives for limited slip or not. How would I find out this on information or what should i use? Oh this is a Silverado by the way. Thank you
I just had mine changed in my '97 2wd .. use regular 80W90 gear oil with no additives.
Your truck may have a G80 Eaton Rear Locking Differential.... but these units DO NOT use a limited slip additive... and in some cases the additive may be harmful to the mechanic operation of this locker...
Here is what is recommended for your truck.
Any good quality synthetic fluid will work. You can pick up Mobil 1 at most auto parts stores. If you are interested in AMSOIL let me know and I can send you a quote on the cost.
Standard Differential, Rear GMT 800......GL-5
All TEMPS......75W-90 [4] [5]
SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
75W-90 Synthetic Long Life Gear Lube (FGRQT)
SAE 80W-90 Synthetic Gear Lube (AGLQT)[4] Synthetic lubricant, GM part no. 12378261,
or equivalent product formulated to meet
GM specification 9986115.
[5] Do not use limited slip additive.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,208 Guests (See full list)
