Wiring Diagrams
reinovator
what is the convence center
:lol: Hello I've been building a 77GMC Panel truck and have 87GMC Suburban as a donor for parts etcthe engine compartment harness is stock from the 77 GMC pickup[ 1/2 ton Grand serria] I'have no power to my instrument panel from the 87 the dash wiring is from the 87 suburbran I've traced, on my diagrams, the problem to the convence center. This I belive is where I need to get power from. I know I Will need to add some power through the 77 harness to the 87 harness . here's the question can you tell which of the 87 need to be I can use to complete this, block teminals ie location 2j, I added power from the battery power through a 25amp maxi fuse. I have 6 more fuse locations I can run power through via a fuse block a aquired. the main reason I'm combinding these two harness is I prefer the 87 steering colum components and the cruise control from the 87. I can post my diagrams I'm working with If this would help. Thank you for your time in this endevor. and if you choose not to help me thank you any way.
oh and yes this is a can of worms but I do my best with what I have, and stop if it could be unsafe.
I WILL NOT PUT AN UNSAFE RIDE ON THE ROAD. My Family and others are worth more than my ego in building a custom ride!!!
Personally, I would say screw the hacking and chopping, and just buy a complete harness from someone like Painless. Its fairly expensive I know, But the headaches and potential fires that it will solve is worth way more than the price of the wiring harness.
Thank you for your cander but in my case 'painless isn't so painless' any other build and I would agree completly! so for my next question is there a place where I can get the referance codes to the numbers listed in the diagrams I'm working with, this is the link to where I got my diagrams http://forum.73-87chevytrucks.com/smforum/...p?topic=11766.0 here's a link to the ones I've partly colored,http://s577.photobucket.com/albums/ss215/reinovator/Panel%20truck%20wiring/ any wat to decypher these I would be greatful thank you again for you quick responce. and again What is a convinence center in this application ? I've been a toyota parts man a Ford partsman and a chrysler partsman. oh I've also been a NAPA partsman I can't find a parts referance to this Item the only thing I can think of it's the chime box?
Thanks Again for your time
Well I found part of the problem the 77GMC is an early 77 and has 76 wiring As they say "Fun with Wiring"
thanks again for your previous help.
    appletrav
    appletrav
  • Who's Online   2 Members, 1 Anonymous, 330 Guests (See full list)
