My 08 Leveled
Just put a rc leveling kit on and new 275/60/20 Cooper Zeon LTZ's on stock rims.
No trimming at all it's like a perfect size for the level.
Only had them on 2 days now but they handle great big difference from stock and pretty quiet also. Like them alot.
