Code 0300 &0303
Guys my truck ran fine last night and this am it was hard starting and then ran rough as hell, I hooked up my obd2 and the codes were 0300 and 0303.
1998 with a 5.7 liter and 208,000 babied miles.
I went and got a new cap, rotor, plugs, fuel and air filter, installed everything and same problem..............
Any help my friends would be appreciated, please remember I drove home last night and it ran PERFECT, it sat overnight and this is what I awoke to. :thumbs:
Thanks
what exactly do the codes mean? i'm too lazy to look them up...i'm thinking fuel pressure or pump...
In your other post on "Classic Truck" -- both threads started on Tuesday
you say you have tested the fuel pressure to be between 52 and 56 psi...
... so first off, you need a new fuel pump, in-tank filter screen, and external wiring harness
... replace these and your troubles starting the truck will likely go away immediately ....
... even if there are other issues.... you still need a fuel pump
Right on the money bro, pump replaced, great pressure!
Still runs`bad though, please follow other thread.
Thanks for your help.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   2 Members, 0 Anonymous, 974 Guests (See full list)
