Tailgate Decals
I have a base Silverado and it came with the Chevrolet black writing on the tailgate.  What can I do to remove it, what can I use??  Thanks in advance...
It just peels off.  You should be able to start it on a corner with your finger nail.  Then just use something like Goo Gone to remove any residue, if there is any.  A lot of times decals don't leave any residue, but there may be an outline due to wax build-up.  After it's cleaned off, just put a coat of wax of two over the area again.   :)
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,071 Guests (See full list)
