97 Tahoe Rear End Vibration
Just last week my 1997 Tahoe started to have a rear end vibration at speeds of 55 to 65 mph. Although I had just had the wheels rotated and balanced in May, I figured I must have lost a weight. So, on Friday I had them rotated and balanced again.
I still have the vibration.
I have 176,000 miles on it and take good care of it.
One thought I had is that maybe the transmission isolator broke, but then I thought - Hey, I don't know if there *is* an isolator. Is there one?
Any suggestions?
Thanks!
Check all u-joints. Also you may have lost a drive shaft balance weight. By isolator, are you referring to the transmission tail shaft mount?
Thanks. By "isolator" I'm referring to the rubber mount (similar to an engine mount) where the transmission is mounted to the cross member. I had a car that had one of these that broke after 150,000 miles. I'm guessing there's one on my truck, but don't know.
Rear brake rotors, u joints, drive shaft, trans tail stock mount, wheel bearing, bubble in the tire?
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 817 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
