87 Chevy 366 Bus Engine Problems
Also, I put a tester on the positive lead of the distributor battery connection with the key in the on position and I am getting 12 volts to the distributor. I will replace the coil and control module in the meantime.
Ok, I replaced the starter and as it cranks, it sounds a lot better and is cranking at proper speed I think. But still, this thing will not fire!! Are there any fuses that could be blown that would cause this???
Things I've replaced: Distributor Cap Distributor Rotor Ignition Coil Ignition Control Module in distributor Starter Battery, holley carb.
Ive checked and there is 12v to the power lead on the distributor. I did the spark plug test and I believe I am not getting any spark.
  • 1 year later...
this is an answer and a question to the no starting bus engine big block. your starting problem is very simple - fuel octane. all the machine heads forgot the first lesson, minimum octane 89 in the 80s big block 366, and if you are buying regular which probably says 87 at the pump, the mafia has fine tuned that pump fuel to about 85,and it just won't run on that. so get some good fuel, royal dutch shelli s about the only non liars in canada, in the us, who knows? and no ethanol, that is no good. i know because my local crack addict keeps spiking my gas and when he does i have to drain the tank, what i want to know is, where the hell is the fuel filter? i cannot find the damn thing.
WTF are you talking about? And I say BS on the octane. Did you see this post is 1 year and 8 months old?
    bellssn690
    bellssn690
  • Who's Online   2 Members, 0 Anonymous, 522 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
