How To Adjust Column Shifter?
My column shifter on my 1989 GMC Sierra c2500 is not in sync with the transmission. When it is in park its in reverse, etc... how can I fix this? Other then that, my transmission works great! This happened when I was trying to change the ignition switch. Thanks.
the back of the instrument cluster has a little "string" hanging out of the back that attaches to the backside of the shifter lever rotating piece on the column. The attachment is adjustable by sliding it one way or the other to make it line up. Do you have a Haynes or Chilton book? It's worth the money so you don't go into this stuff blind.
    hotfish
    hotfish
  • Who's Online   5 Members, 0 Anonymous, 815 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
