Remote Start Bypass Keys
wolverine_22
My wife has an Avitol model 4103 remote start....it was on her 06 jeep grand cherokee...and now they guy who installed it says he has to buy a new bypass key to transfer it over to her 09 journey....
Is this what hes buying I think i found it for $24.00???....
//ProductCategory-P4450:1065 function add_P4450(type,temp){ addingToBsk=true;if(tf.coreLoaded&&tf.wm.pProp('P4450')){return core.load_add(d,type,'P4450','XpressKit XKEYCH Chrysler/Dodge/Jeep Xpresskey Bypass','1.00','XKEYCH','0',0,'TD3,TD4','','','','',opt,isInSF(),s,'-1.000',temp);}else{setTimeout('add_P4450();',500);return 0;}} mfw(); <H2 id=ProductTitle-P4450 class="GC5 ProductTitle" sf:object="ProductTitle">XpressKit XKEYCH Chrysler/Dodge/Jeep Xpresskey Bypass
Second one going down the page>>>
http://www.carmedia1.com/index1.html</H2>
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,183 Guests (See full list)
