Common Rust Spot For Brake Lines?
anybody else have brake lines showing rust right by the master cylinder just inside the driver side wheel well liner? when i asked about it at the dealer i was told its common...is this just a retarded idea by gm or what to leave that stuff exposed? mine are starting to become covered in rust and the trucks only 6 years old :thumbs:
Mine don't have an once of rust on them, not even under the truck along the chassis. But, I wouldn't think that rust by the master cylinder would be normal, I've never seen brake lines rust there, not even on 30 year old trucks. Don't let them tell you it's normal, it could bust and you could lose your brakes. Many GM trucks did this around that area, just do a search on google about silverado brake lines busting from excessive rust spots.
mine are corroding at the same spot just under the wheel liner on both sides. my truck is only 4 years old. i took it in as my brother has a 2500hd and his brake line corroded through and exploded but the dealer said it was fine that is was just lite surface corrosion.
mine are fairly rusty, and i thought it was weird that this was common....right on the frame where the lines are exposed to whatever the tire decides to chuck in there is where it is the worst..i live in an area with pretty harsh winters but i mean really they coulden't have covered the engine bay a little better?
11 years and mine are still shinny and no rust.....
But I am not in a snow or ice area....... So no Salt......
Jbo
    appletrav
    appletrav
  • Who's Online   0 Members, 0 Anonymous, 401 Guests (See full list)
