Front Diff Removal
Is there a trick to get the front diff out of 04 yukon? It's loose but it won't come out.Thanks for the help.Jeremy
When I did my 03 Denali I had to turn the front wheels all the way one direction and then wiggle it. Mine came out and when back in with out taking any suspension parts off .. I hope this helps!......... Scott
[email protected]
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,058 Guests (See full list)
