07 Suburban With Nav -- Scratching Cds/dvds
Recently bought an 07 Suburban with factory Nav that is putting circular scratches on CDs and DVDs. It also clicking when it spins up the discs. This started happening after watching a DVD (w/o issue the night before). Started up the next day and it started making a bunch of clicking sounds and wouldn't eject the DVD. After holding the eject button down about 10 times, it finally spit the disc out.
At this point any disc I put in would result in "disc read error". Fixed that problem by pulling the fuse, but since then, the clicking and scratching has persisted.
I assume it's an alignment or mechanical problem, but hoping there is an easier fix than sending off for repair (or replacing).
Let me know if you have any ideas.
Bumper to bumper has expired and it's not GM certified.
Thanks,
Dan
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 507 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
