1996 Abs T/s?
On my 1996 Z71 with 5.7, the ABS light has come on. No BRAKE light, just the ABS.
I know there's a way to troubleshoot the ABS on the PRE-OBD-II trucks, but is there a procedure for T/S the system on a 1996 other than with a scanner? My AutoXray does not have the ABS function. I've already bled the heck out of the system and left the battery disconnected overnight to see if that would help. It didn't.
Just a stretch here becasue I have not actually worked over the ABS system on my 92. Seems I remember having this issue with a 96 SBlazer and the problem was just a bad wire at the sensor on the wheel hub. I think I remember a few folks just spray electro-clean on the contacts too and that re-establishes connectivity. Maybe someone else will chime in, but I would move to the wheel/sensor area next.
--Mike
Thanks for the reply. I've been doing some reading and while I've read that the wheel speed sensors have to be replaced as part of the hub, I'm seeing the sensors for sale by themselves. Confusing.
I've also read where you can hook up an analog VOM to the sensors, spin the wheel and get a slight voltage output if the sensor is good. Since my scanner does not have ABS capability, I'll give that a shot this weekend.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,049 Guests (See full list)
