Hid Lights For 2009 Gmc Sierra
I am looking for a good place/site to buy HID headlights. since my truck is an 09 it uses the low beams for DRL's. any help would be awesome.
thanks for the info. i heard that they dont work or that i need to do something if my daylight running lights ar emy head light?? do you know of any issues?
I have been quite happy with my DDM Tuning HIDs.
u turn your light switch backwards your day time lights go off! Im about to get low/highs and fogs
yeah i figured that out... question is if they are on will it hurt anything? i cant imagine they would but better to ask a stupid question than fix a stupid problem. oh and i called the website number and the one in san deigo was not a working number and the huntington beach one no one answers??
i see people driving round the day with HID's on that just wast the life of them. You will be fine.
i need to know what i need for fogs,high beams and low beams. I was thinking about 8000k? 35W or 55W?
Just pull the fuse for your DRL's. If you go into a parking garage and you don't want them to come on in AUTO turn the knob 1 click clockwise to the runnung lights and the headlights will stay off.
I've had mine for 2.5 years now and they're wonderful. I could never go back to stock.
thanks guys... i have a new question... i called the place DDM and they dont answer the phone?? the one in san diego is disconnected?
I bought all mine from "Hidgate" on Ebay. They also sell under the name "kickxtc" and "lighting623". They sell pretty much any set for $40 shipped.
Not sure. I ordered online. You will want 35w for the fogs. I would go 55w for the Hi and lows. I have an 02 Yukon XL Denali. I did not need a harness to run my 55w low beams. I went with the slim ballast.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
