4 Wheel Drive Engaging Problems
fossel
2004 Silverado 2500HD 4X4 6.0 litre. When engaging 4hi on the fly the gears don't syncronize they grind. The 4 wheel drive works fine in 4Hi and 4Lo. This is NOT an auto 4 wheel drive, just 2Hi,4Hi and 4Lo Front diff. actuator works, encoder is working. Drained T-case, no fragments. I have replaced the dash switches and the encoder sensor. Haven't gone to get codes read. Do the front wheel ABS wheel sensors have anything to do with the syncronizing??
you wasted a bunch of money Jim,
the t case case to out and apart and the syncro HAS to be replaced ,poof its fixed ,
i've seen this movie many times at the dealer.
ABS has nothing to do with it
Thanks for the reply. Dash switches needed changing. Can you explain your answer, I don't quite understand, does the transfercase have to come out and is there a syncro in it. Is the a straight forward job.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,113 Guests (See full list)
