Re-installing A Canopy
I took my canopy off for the summer, it was on for 2 years. Just wondering, I can't get the canopy to seal completely, is the canopy tape one time use only?? Advice?
Pretty much. The tape will only cost about $5 for a new roll at a hardware store (weather stripping) and it makes good sense to remove the old and use new stuff, but I would deffinately use 2 strips side by side.
I got some new tape, it actually pretty cheap at the place I got the canopy, I got the wide stuff, plus the guy there said that box style is hard to seal at the front corners by design, so there ya go.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
