Squealing Coming From Wheels
harrfd24
The other day I started hearing squealing coming from my wheel/tire area while driving. When I applied the brakes the noise went away. Now the squealing is still there, but I continue to hear it both while drivning and during braking. I'm thinkin the rotors need replacing, but could it be both or just the brakes? Should both rotors and brakes be replaced together? Thanks
Nat
Depends on how much life is left on the rotors.. sometimes they can re-surface the rotors and replace the pads. The key is to use a good quality pad. I'd suggest the good pads found at NAPA, and even some of the GM Pads are good. If you go to a discount brake store, they'll use discount pads that suck and won't last long.
After much research, these will be the Pads that go on my truck when it comes time for new brakes.
http://www.napaonline.com/Search/Results.a...Keyword|Keyword
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,049 Guests (See full list)
