Integrated Bluetooth
scott11024
I have a 2009 Tahoe with most all options except bluetooth. Can anyone tell me what component has this functionality? Is it OnStar or the stereo/nav. Secondly, What is the GM part number that I can buy that will enable this functionality. I have purchased the CoastalTech product and had limited success and ultimately I had to remove it.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,049 Guests (See full list)
