Abs And Brake Lights
Norseman
Well after 202 thousand miles my 1999 Silverado has given me a problem I can't figure out. The abs and brake randomly come on. At first I thought it was a bad ground because when I turned the truck off and restart they would not come back on but out of nowhere (randomly) they would turn on and not turn back off until the truck was restarted. Any of y'all run in to this problem?
On my 2001 silverado with 180k i recently ran into and currently have the same problem of random abs and brake light. I don't remember the code number but on my truck it was the ABS relay circut malfunction. I havent fixed it since i havent wanted to pay to further diagnose the problem. The guy that scaned the code for me said the first thing they would do is check and clean all ABS connections.
'99 Silverado 5.3 auto.... same issue. Started about 9 months ago. I was told try cleaning or replacing ABS sensors. Haven't done it yet. Lights come and go.
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
