Rear drivers side rotor
Take a look at this pic.  At like 18K miles i had the rear pads replaced and rotors turned because of a loud squeak.  Came back a wk later.  I took the tire off and sanded the surface rust off the rotor.  No squeak till about a month ago (lasted almost a yr no squeak).  Well today i got tired of the constant squeak at slow speeds.  Used an air compressor and file and sanded off the surface rust again (lots).  No noise for now im keeping myy fingers crossed
Ryan, for what this is worth - did you get a look at or feel the in-board pad side of the rotor?
Mine had a very weird wear pattern - it had a center ring of about 1 cm wide that was making useful contact, and the other outer and inner rings, on either side, were raised rust!!  This is what was making the noise on mine, especially when the brakes get a little warm.
Bizarre!
:eek:
    appletrav
    appletrav
  • Who's Online   1 Member, 1 Anonymous, 325 Guests (See full list)
