1999 Gmc 2500 Crew 4x4 454 Fuel Issue
Chilledspode
VIN 1GTGK23J2XF049426 with 185,000km
The best way I can describe the issue is it keeps giving codes related to rich conditions at the O2 sensors. I have replaced every sensor I can think of over the last 4 years including crank position sensor, temp sensors, new injectors, EGR, etc. The truck on very light throttle (think of moving in traffic at 20 mph and smoothly feathering in throttle to maintain speed) the jetting comes apart and the truck stumbles and breaks up - more throttle/accelerate and things cleanup.
As part of this issue if you get the truck hot and then let it sit for 2hrs and come back to start it - it floods, it runs on the starter for 10-15secs blowing black smoke and starts on a few cylinders at a time followed by a full start - you can smell the raw fuel from 100ft away. Everything we can think of is in spec, fuel system has been leakdown tested all the regulators have been changed out, all sensors are in spec and the only thing that makes any sense to me is the truck keeps thinking it's cold and calls for more fuel than it needs but no one can figure out why.
We are currently chasing a possible bad wire between the ECT and the ECM as a possibility but after that the shop has nothing left to try other than replace the ECM.
The truck is in a small town so it doesn't do any highway running and I have spared no expense in maintenance trying to fix this long standing issue - I am wishing it had a carb so I could just rejet the stupid thing...
Any suggestions would sure be welcome.
Thanks for your time
Mark
Have you replaced the CTS on the intake manifold with the yellow & black wires? It controls fuel enrichment. I suggest that you go to some shop with a Tech 2 or similar scanner and have them watch live data.
Sorry, I wasn't very clear on that aspect - the local GM shop has been doing all this work and they are stumped.
The Tech 2 isn't providing any indication of what is causing the rich trim codes at the O2 sensors only that it is occuring..
Cheers
Mark
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 393 Guests (See full list)
    • 2013 5.3 still to this day calls for the PF48 filter.  Which as a 15psi bypass pressure.     There is a TSB, 17-NA-157 that talks about the PF-63 and PF-64 filters which have a higher bypass rating of 22psi.    TSB HERE - temp.xml   "Beginning in 2012, the oil pumps began to regulate main gallery feedback instead of pump out pressure. This means that the oil pump now does not begin to regulate until pressure is built up to the main gallery. This change reduces the amount of time it takes to provide oil to the engine bearing and lifters during extreme cold start conditions.  Main gallery feedback oil pump control systems are present on the following engine families which use Spin-on oil filters: Small Gas Engine (SGE), Large Gas Engine (LGE), High Feature (HFV6) Gen2 and Small Block Gen5 gasoline engines. These engines with the main gallery feedback oil pump control systems are factory built with an ACDelco® oil filters"   It also calls out what engines use those filters.  The gen 4 small blocks were not on that list (LMG, LC9, L9H, L92, L94, L20, L96).  Gen 5 small blocks use the higher pressure filter.
    • To me it honestly makes zero difference what filter you run. It's not a race engine, just a truck engine that's mostly bumming highways and it just needs a filter that filters oil.   The filter used to be a 7060 and the long version was a 7045. Now it's the newer updated filter that the K2XX trucks and newer run, the 100255 I believe if we are using napa numbers. Any of those filters is going to do the job.   I wouldn't overthink it, to me it makes no difference because those first filter numbers worked for 18+ years before the spec suddenly changed.
