Frustrating Misfire Problem
Kirkathon25
i know i have been talking about this but i realized i put my posts in the wrong topic.
i have an 02 gmc sierra 6.0L and i have been having an intermittant misfire problem for a couple of months now.
it started when i put bosch plugs in but i swapped those out for ac delcos with msd wires.
i have also replaced the pcv valve, the fuel filter and i cleaned the tbi and the maf.
i have disconnected the battery for an hour to see if it would reset, i have sea foamed it, i have run a few bottles of injector cleaner through it.
the service engine light is only on when the truck is off and when it misfires for a while it flashes for about 30 seconds and it stops (p0300).
it only starts to misfire when the engine is warm and it starts only while the truck is idling and it stops when i push the gas down and hold it. the fuel pressure is fine.
i really have no idea where to go from here and any help would be much appreciated.
I had this exact problem with a '00 Jimmy. I had narrowed it down to either the spider injector assembly or crank position sensor.
I got frustrated with the truck (former rental), & am parting it out now. GM really dropped the ball on those late model Blazers/Jimmys .. but that's another story for another day.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 665 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
