Door Panel Removal
I think I figured it out. On the rear ones there are two hex nuts that hold the panel on, and then all you have to do is lift. Do the fronts come off the same way?
the fronts are similar but there is a triangular piece you in the front corner behind the sideview mirror. pry that off with a screw driver. then you need to remove tab for the lock. to do so pry behind the whole assembly. the little piece you push on, and the piece behind it come of as an assembly. the you need to pry out the power lock switch the same way. im not sure how to get the power window switch out cause my truck has manual windows in it. if yours does too, there is a metal retaining clip behind the crank, just pull on that with anything hooked like a piece of coat hanger, and the crank comes off. then there is a screw under the armrest, and i think there is one or two around the bottom of the perimeter. after all that, just lift up and out like the rear door panels
Guest pjblurton
Power window and power lock switches come off with the whole door panel. Just don't pull too far and unplug the harness from behind the door panel.
Thanks guys, I was able to figured it out on the weekend. I removed the two screws, one at the rear and one under the arm rest, then there was that push type screw/clip but I could not figure why it would not come off. I then realized that there was one left under the door lock latch, pried that off and got the last screw.
Thanks again.
    CaptainDad
    CaptainDad
  • Who's Online   3 Members, 0 Anonymous, 566 Guests (See full list)
