50,000 Mile Maintenance
So, I have a 2008 sierra that I bought in July of this year, this is the first newer vehicle I have purchased that has a warranty, and I do not want to do anything to void said warranty. Here is my dilemma, I am nearing the 50,000 mile mark, and want to have the maintenance done to keep the warranty in check. The Stealership is telling me this maintenance is going to run me appx. $750. This seems a little outrageous considering I have only put about 4,000 miles on a vehicle I bought GM used certified. What route should I take with this, I know i can probably have local shops do the work and save $$$, but I am trying to keep everything easy paperwork wise. What exactly does the 50,000 mile maintenace entail? Service guy said replace pretty much all fluids in the vehicle, but it seems that should have been checked/taken care of in order to sell it as certified, am I wrong? I live on a budget, and anticipated shelling out a couple hundred bucks for this, was not anticipating the quote given. Any info would be appreciated.
Thanks, Tim
Depends if you wanna do a flush or a standard drain and filter replacement. I do the standard drain and filter replace, and on my HD it couldn't be easier, don't have to drop the exhaust or nothing like that. A flush is easy, take it to a car amintenance shop and tell em' to lfush it takes a couple seconds and is pretty cheap, you can do it yourself though. But, I don't like the flush idea, myself.
    Sothpaw27
    Sothpaw27
  • Who's Online   5 Members, 0 Anonymous, 688 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
