What Happens When A Transfer Case Grenades Itself?
pwjz71
I have a 2001 Silverado Z71 5.3L with a NVG246 (AutoTrac) Transfer Case.
I have 2 questions.
1. What happens when the Transfer Case suffers catastrophic failure aka grenades itself?
2. Will it cause failure elsewhere in the powertrain as a result….ex. driveshaft, transmission etc?
I appreciate any help or knowledge you can give me!
Depends, sometimes it can blow a transmission because the gears bind and stop the tranny so fast but the engine is still going, but generally it doesn't take out a diff. That's usually the other way around, if a diff goes, a tranny or a case usually goes as well, especially if it goes under moderate to heavy acceleration.
I would also be worried about WHY it grenaded in the first place.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
