Gm Window Control Switch
Mike E.
For Sale:
GM window control switch. I am not sure what they fit as I am selling them for a friend.
Asking $30 plus shipping.
thanks,
Mike
Is the passenger window control switch and the driver switch from the same vehicle that had the DL3 mirrors that you also have posted, as I may also be interested in the switches.
These window switches WILL work with these mirrors.
The mirrors are off a 2007 GMC Sierra LTZ
I am not sure what the switches came off of but the mirrors do plug in to them.
Sorry I cannot be more help.
Mike
Those switches will work with the mirrors but your stock switch will as well to make the signals work.
If your truck came with the DL3 Power fold/Turn signal mirrors, this stuff will work.
If the truck just had the regular mirrors, the power fold WILL NOT work. The power adjust and the turn signals will work, but the power fold will not work unless you do some extensive re-wiring on the truck as well as new door panels etc etc
AustinZ71:
Thanks for your post! I hope this will help people understand how they will work.
Thanks Again!
Mike
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 950 Guests (See full list)
