Dash Cam And Dvr..
Wifey wanted me out of the way while she and my daughter cooked the bird, so I did some mods I was stocking up..
first, I installed a Dash Cam and DVR system. back in August my mother was in an accident (she was ok) where in some lady ran a stop sign and turned left in front of her and totalled her new Caddy that I had just bought her for her birthday in June..
there was a big fight with the insurance company over who was at fault, but thanks to a witness (school crossing guard we later talked to) my mom was found not at fault, but the hassle led me to decide to install these into all our cars..
found this on ebay for $135, and the mounting bracket from RAM-Mounts for $25, it's wired to the ignition so it starts recording at key on and stops recording at key off so there is no need for any human intervention..
it will record to a 2 or 4gb SD chip and once full it will delete the oldest file and continue to delete/record, it marks the files by date and time, so you can pull the AVI file off onto your computer anytime there is a need.
it will record sound, though you can turn it off, I did, no one needs to hear my awful singing along with the radio..
it records in HD 1280 x 720 DPI and the images are chrysal clear.
the Ram mount goes between the windshield and mirror, using the OEM mirror mount, however it is not compatible (as stated on the RAM mount site) with the onstar mirror, but a little trimming with a dremel tool resolved that issue (the onstar mirror mount is a bit thicker so triming of the slots that slide over the mount was required).
i've attached a boring video of my drive to work this morning so you can see how great the video comes out.. (it's 15 min just FYI) though the youtube conversion to make it fit their specs looses some of the quality, but it is crystal clear in it's original format.
http://www.youtube.com/watch?v=wKrip-BS0n0
here are some pictures of the install:
It's slightly hangy, but it's still a good cam. Very clear. You didn't stop at the stop sign, though. And I would rather hear you sing than silence. :thumbs: Looks like a nice sunny day to.
what stop sign? there are no stop signs on my route to work, only lights..
The one as you pulled out the shopping center. They call that a California stop.
sure I did, it's called a California Roll.. seeing as I am in CA and all... (actually I jumped to beat the light that is about 50 feet to the left which you can't see in the video, else I would've sat there for 20 min)..
Good move!! 20 minutes is a long time to wait.
that light only changes when there is traffic on the side streets and the side streets are residential that exit out of a housing tract.. believe me I have been stuck there for 15 - 20 min before, as that street i turned on (Lakewood Blvd) is the main thoroughfare thru my city, 45mph speed limit and goes from 4 lanes just south of the light to 2 lanes as you approach the light then back up to 4 lanes right as you pass that shopping center and residential area, before the freeway on-ramps to the right..
here is a night vid guys..
http://www.youtube.com/watch?v=g2o7O3UTWbc
and the info on who,what,where:
i purchased it here:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...e=STRK:MEWNX:IT
seller was great to work with.. no issues there.
the unit comes with a cheap suction cup mount, i opted for something more stable, so I got the ram mount from GPScity.com
RAM Mount Camera Mount mini Plate RAP-B-366U
Model: RAP-B-366U SKU:RAPB366
RAM Mount Plastic Lite Arm B-Socket RAP-B-201-1U
Model: RAP-B-201-1U SKU:RAPB201-1
RAM Mount Plastic Mirror-Mate Cradle Mount RAP-B-191BU
Model: RAP-B-191BU SKU:RAPB191B
The video with no sound is NO FUN!
Everything is better with Yakety Sax.
So...Here's your video run through the Benny Hillifier: http://bennyhillifier.com/?id=wKrip-BS0n0
buwahhahahahahahahha that cracked me up.. thanks for that...
You can copy/paste the url of any Youtube video in there BTW. It can make for some HILARIOUS mashups :thumbs:
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 414 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
