Truck Has No Power
i have a ( 1991 Gmc Sonoma 4.3 v6 ext cab truck )
i went to go and start it the other day it worked i then turned on my heater and the truck just died and never re-gained it's power back
with that said
i changed my ( ign switch on the lower column ) and changed the fusible link in the starter soliod ) neither one of these did anything for me i checked my battery and it is good
checked links on m alt they are good
i have head lights brake lights and a dome light that works
when i put my key in and tuen it to me i get the radio to work but that is all that works in my truck
no dice i looked at the power wire going to the starter and it's good
looked at the ground wire and it's good
i re-re-placed the fuseable link on the soloind no dice
looked for loose wires around the engine all good
looked under the dash panel at the fuses
all are good -except i found one ( shunt fuse ) that would not light up on my tester light what does a ( shunt fuse ) do any way
found problem its works now
probly had it in gear ...anyways thanks for the info as it may someone else out in the future :thumbs:
    Dig Deep
    Dig Deep
  • Who's Online   4 Members, 0 Anonymous, 640 Guests (See full list)
