Ipod Hookup
hrspwr
Hey guys, I have been looking to play my Ipod on my factory stereo. I have the Bose system with onstar but without xm. I have read that there are a couple of ways to do it. One is to solder in a 3.5mm jack and then hook up the Ipod that way. I am not sure if that will work on my system as I do not have XM and I think I read somewhere that I need to update/flash the radio to do so, Is that true?
The other route is this:
http://www.sonicelectronix.com/item_12222_PAC-uPAC-GMC2.html
Has anyone ever used one and are they any good?
There is a big price difference and that is why I wanted to know what you think and your opinions/help. Thanks
I can't speak from personal experience because I have an aftermarket deck. But my friend has one of those pac ipod connector things and it's really nice. It turns your ipod off when you turn the truck off, it allows you to change songs from the radio and steering controls. But, it did get XM error the other day and he called me to fix it, and I just pulled the radio fuse and it reset the pac and now it's good again.
Ya I like that unit, looks pretty clean. But if I can get away with doing it for less then I will, just need to figure out how. I saw a post either here or another site where someone did it, all they did was solder in a jack and it worked. I would like to see how it is done or if anyone has done it how to do it.
I can vouch for the PAC iSimple interfaces. I have installed one in my truck and one in my sisters Pontiac G6. The sound quality is great and the wiring harnesses are plug and play and look factory.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 410 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
