Removing Intake On 2003 8.1l Suburban.
I assume you have to drain coolant but I cannot find the drain petcock. ANything else special that needs to be done to do this? I already have all the connectors marked and disconnected just trying to drain the radiator so I can pop it off.
check both sides of the radiator. my drain is on my right side, (if you are standing infront of your truck looking at the engine.) it is a long hose that is clipped on the side, you un clip it and point it at the ground, and at the bottom of that is a little dial, turn that and it will drain the rad. hope that works.
also check the manual it must have something in it
Yeah I found it. Made a pretty good mess next time it would be helpful to jack on side up. Speaking or lower hoses, I wanted to replace mine since I am in there and it looks like something has been rubbing one spot. Its a real crazy looking hose with a coulple of extra pieces to go to the heater, and I dont see how its removed from the radiator. It has spring clamps on the engine and heater but I see no clamps on the radiator side. Suggestions?
    250.3k
    Disabled Mike
    Disabled Mike
  • Who's Online   2 Members, 0 Anonymous, 739 Guests (See full list)
